This is REALLY bugging me out!
Old Jun 2, 2008 | 05:06 PM
Zoidberg's Avatar
Default This is REALLY bugging me out!
I've finally installeda MBC to get rid of the boost-fluctuations and everything works great. Except for one thing.
My chip boosts 1.35 bar. My mbc is put to 1.3-1.4 bar. BUT, after driving on full throttleon 4th and 5th gear a little while, the car chops, probably fuel-cut. No overboost, just stable boost around 1.3-1.4 bar.
This seem to happen ONLY when it's getting a little cooler outside.
So what's the deal? It can't be the boost, because as I said, the chip is set to 1.35 bar and the car peaked @ 1.45 earlier today without any problems.
I also changed my spark plugs to platinum plugs.
Please help! :'(
Old Jun 4, 2008 | 10:43 AM
Zoidberg's Avatar
Default RE: This is REALLY bugging me out!
I've tried to lower the boost, and it get's better, but am I supposed to lower the pressure everyday it gets colder? sounds strange.
Please help!
Old Jun 4, 2008 | 11:56 AM
cincyTT's Avatar
I'm make believe
what mbc?
how is it installed?
spark plug gap?
Old Jun 4, 2008 | 05:38 PM
Zoidberg's Avatar
&lt\\;P&gt\\;A mechanical, the one i showed you.&lt\\;BR&gt\\;I have the bleed-side plugged into the recirculation, where the n75 was. After the MBC is a tee to reach my desired boost (1.3bar) otherwise i will only get maximum 1.1bar&lt\\;BR&gt\\;The plugs are brand new platinum ones, NGK PRF 6Q, i don’t know the gap.&lt\\;BR&gt\\;&lt\\;/P&gt\\;
Old Jun 6, 2008 | 06:18 AM
Zoidberg's Avatar
I noticed that when I'm on fifth gear and a little load (still chilly outside) the boost raises to 1.45bar insted of the set value of 1.35bar.
is it because of the placement of the tee?
http://www.nordicaudi.com/php/files/882136-DSC02066swe.jpg
If i move the tee to before the MBC, will i get rid of the unwanted increase? will my spool-up be affected?
C'mon, someone had to have this problem before
Old Jun 6, 2008 | 10:48 AM
Mike-2ptzero's Avatar
What year car and does yourcar have a boost sensor stock?
Phixer
Aug 12, 2014 01:22 AM
sljone
May 29, 2007 10:15 PM
plumbous
Dec 30, 2005 07:21 AM
wrax
Jun 15, 2005 02:41 PM
