Rear Caliper
Old Jul 24, 2012 | 06:00 PM
audivalley's Avatar
Default Rear Caliper
right rear caliper seems to be dragging. After a drive I can smell my brakes and the right rear is hotter than others. Also I can hear it more when rolling the car when its off. New caliper? Where to start?
Old Jul 24, 2012 | 06:03 PM
vgo's Avatar
vgo
I've read a few times it could be your guide pins. Take em out and inspect their condition and regrease them.
Old Jul 25, 2012 | 09:30 AM
mtroxel's Avatar
+1 I've seen 'em rusted so bad I had to put the entire caliper carrier in a vice to get some movement. But I sanded them down and greased 'em up and they were like new. Just make sure the little rubber boots aren't cracked and fit on there to keep water out.
Old Jul 25, 2012 | 08:21 PM
FishEye's Avatar
sounds like a common slider problem... take the caliper off and inspect the slider pin / bolts ... if they're hard to move around take em out somehow and use sand paper and sand em down a bit to get all the rust / dirt off and throw some wheel bearing greese on there put it back and ur caliper should be sliding in and out like normal now
Old Jul 25, 2012 | 08:34 PM
crazyquik22023's Avatar
˄ Like they said, start by taking off the guide pins and getting all the rust off then regrease them. I would also take off the brake pad shims and clean those up as well. If the shims are rusted your brake pads could be getting stuck to them and cause them not to move all the way in and out. I've found it is much easier if you use a wire wheel rather than sand paper but either will work.
Old Jul 26, 2012 | 01:19 PM
audivalley's Avatar
Yea I will look at them this weekend and sand it all down maybe paint them too. Or just buy s4 rears!
Nemick
Mar 20, 2013 12:01 AM
audivalley
Jul 24, 2012 09:30 PM
mandito219
Feb 3, 2009 08:09 PM
audi_kris
Jun 29, 2007 05:59 PM
kakarot
May 4, 2007 01:51 PM
