rear caliper gone bad.. HELP!!!!
Old Feb 2, 2009 | 08:17 PM
mandito219's Avatar
Default rear caliper gone bad.. HELP!!!!
I was changing the rear brakes when i decided to take out the brake fluid line to make things a little easier (from the caliper) . When i tried to put the brake line back the screw wasnt straight so the caliper thread got messed up a little. any suggestions on what to do? now the screw wont go in.. and I dont want to force it in. should I rethread it?? HELP!!!!!!!!
I dont want to buy a new caliper if theres anothe optin PLAN B ANYONE??
Old Feb 3, 2009 | 12:01 AM
myslow1's Avatar
tap and die set for the win!!!!
no idea why you removed the brake line when you didnt need to though...
Old Feb 3, 2009 | 05:13 PM
achTTung's Avatar
+1 on the tap and die.
+2 on the not removing the brake line. You'll cause yourself more grief removing that and needing to bleed the brakes than if you just left it in place.
BTW, note to anyone who didn't know... Don't let your calipers hang by the brake line. Stresses the line - no good. Hang the caliper with a piece of wire/twine or something.
Old Feb 3, 2009 | 05:29 PM
myslow1's Avatar
i like to find a strategic place to put it... if that doesnt work i use a hanger lol
Old Feb 3, 2009 | 06:40 PM
achTTung's Avatar
I must confess, I often just find places to wedge it as well.
Old Feb 3, 2009 | 07:43 PM
mandito219's Avatar
thanks it was my BAD Imagination IT went in today it was just too dark and couldnt see. AND You are right no need to take the line out. Now the brake hose the one that connects to the caliper is leaking. not from the screw but from one of the sealed joints. dont know how to explain it better. where can i find the caliper hose? anyone?
Old Feb 3, 2009 | 07:58 PM
myslow1's Avatar
just get ss braided brake lines and call it a day
Old Feb 3, 2009 | 08:09 PM
achTTung's Avatar
Stainless braided lines would be a good upgrade. Cant just use any though, Audi uses a diff thread, so its gotta be Make specific. It also wouldn't hurt to flush the brake fluid fully.
ATE Super Blue is a good fluid, and their Gold stuff is as well, and compatible with each other. Whats nice is that since they're different colors, you'll know when the system is completely flushed if you alternate between the two.
Wilwood also makes good brake fluid, and a bit cheaper than the ATE stuff, although I don't know what the situation is with compatibility with ATE, if you were to flush between the brands.
Standard brake line would probably be a dealer part, ECS only sells stainless kits, $125 for all the stainless lines you'd need, and you'd still need fluid.
Nemick
Mar 20, 2013 12:01 AM
audivalley
Jul 26, 2012 01:19 PM
audivalley
Jul 24, 2012 09:30 PM
audi_kris
Jun 29, 2007 05:59 PM
kakarot
May 4, 2007 01:51 PM
