rear differential questions
I was wondering does a b5 a4 Quattro have a viscous clutch differential, or an open differential. If neither which one does it have stock. I'm having trouble deciding if I should upgrade and if I choose to what would be a hood direction to head
Pretty sure the wavetrac one will go into the front differential.
OP, if you are interested in a LSD rear diff, look into swapping in a 944 LSD. It has been done but requires some modding.
That's the thing that sucks about b5's. Some b4's got electronically locking center and rear diffs with the front always remaining open. Instead, b5's got stuck with open front, center, and rear diffs effectually making it an AWD one wheel wonder.
I believe it was only an option in 2001, but some a4's do have EDL. However, it has nothing to do with the differential. The ABS pulses the slipping wheel and the open diff takes over and transfers torque to the non-slipping wheel. Only in the back.
