Rear differential leak
Old Dec 11, 2005 | 08:56 PM
drkenan's Avatar
Default Rear differential leak
I noticed last night that I had something hanging down under the car. So I got looking at it today and it turned out to be a broken exhaust hanger. Not a big deal, but when I was down there I also noticed that the rear differential was leaking. It's not dropping on the ground or anything but the case is definitely wet and dirty.
Does anyone know how to tell if it's something that needs to be done immediately or something that can wait? I found a write up on AW about how to change the seals but I'm not positive that the seals are leaking, so I'm really gonna have to do some dirty digging. Has anyone had a similar problem? Thanks in advance.
Old Dec 11, 2005 | 09:10 PM
david9999's Avatar
Default RE: Rear differential leak
Not an urgent problem, but make sure that the gear oil isn't low if you car going to delay for long
Old Dec 11, 2005 | 09:16 PM
drkenan's Avatar
I appreciate that. The Chilton manual says to check it with your little finger but that sounds kind of funny to me. Does anyone know if that's the only way?
Old Dec 12, 2005 | 12:13 AM
david9999's Avatar
It should just dribble out when you remove the fill plug (assuming the car is level). Have some gear oil on hand and when you check the level, fill it until it starts to flow out. then insert the the fill plug
banku
Dec 2, 2013 12:27 PM
pradipsahu
Sep 16, 2013 10:20 PM
lydiacallaghan
Aug 20, 2010 06:33 PM
shovin
Mar 14, 2007 07:03 PM
psaario
Sep 21, 2006 04:26 PM
