Rear sway bar arms rubbing CV boots after axle install
If you do, you'd better take their axles back with you. If you're in their shoes, I'm not sure you can do much except give your money back. Just looking at your pics, I'd swear the diameter of the axle is a bit bigger too. Just not a good part.
Just a shot in the dark, but are you sure that you have the end links on the correct side. There are different part numbers for the end links because they have a kink in them to allow clearance for the rear axles. The PO of my car put them on the wrong way and I noticed that the shaft had worn half way through the plastic.
I have also installed reman axles with different boots and with the metal endlinks have no clearance issues with the axles.
Cookryan83
Jul 3, 2013 04:40 PM
