Rear wheel bearing help - Pittsburgh, PA area
Old Oct 25, 2012 | 01:28 PM
ooyawn's Avatar
Default Rear wheel bearing help - Pittsburgh, PA area
Is there anyone around the Pittsburgh area with access to a press/hub shark? I need to replace both rear wheel bearings and am not having much luck finding a shop willing to take this on. Thanks, Ian
1998 A4 2.8 Quattro manual avant
Old Oct 25, 2012 | 06:58 PM
AudiDeficitDisorder's Avatar
I'm not in the Pittsburgh area, but if you a Harbor Freight in your area, look for their wheel bearing press tool kit. Very similar to a hub shark, just a little cheaper.
http://www.harborfreight.com/fwd-fro...ers-66829.html
Old Oct 25, 2012 | 09:48 PM
redmond1501's Avatar
Pep boys did mine for $50 in labor each.
Old Oct 26, 2012 | 03:45 PM
jonbonesjones's Avatar
Moderator
I dont think the harbor freight bearing puller is getting the Audi hub out of there. Pop them off the car take them to a shop and have them pressed.
Old Oct 26, 2012 | 04:03 PM
ECS Tuning's Avatar
Sponsor
I would just give a few different shops/ dealers a call and ask if they can press and bearing in and out for you. Usually shops will charge you 20-50 bucks per bearing.
Good luck!
Jason
Old Oct 27, 2012 | 07:22 PM
The diy I used said that you can just hammer the hub out the upright then use the harbor freight tool from there.
Kyle_vdk
Jan 11, 2014 10:25 PM
MadMaxGT
Apr 30, 2007 08:41 AM
Ford2Audi6
Apr 23, 2007 01:36 PM
jkucz28
Oct 19, 2006 03:18 AM
skidplatexa4
Nov 21, 2005 02:47 PM
