rear wiper has me puzzled plzz help
Old Apr 5, 2011 | 09:07 PM
slowb5avant's Avatar
Default rear wiper has me puzzled plzz help
hey how's it going everyone? My 1999 a4 avant has really got me puzzled. I got the car in november of 2010 an the rear wiper wasn't working but the rear washer jet was working. I checked all fuses an they all look good. I then replaced the rear wiper motor with an aftermarket unit an still its not working. This time the washer jet wouldn't work. I tested the terminals on the plug in the hatch with a multimeter an I'm getting a positive 12volts. I then pull off the relay panel an pull out relay number 389 which controls the front wiper an washer jets an I tested that which came out good. Now when looking at the relay plate second row I've got horn,load reduction,number 3 blank,fuel pump,front wiper?washer. My question is there suppose to be a relay in the third spot on a 1999 a4 avant? My repair manual has that spot blank aswell. I'm assuming only the avants have a rear wiper an I know they work on there own relay. Could someone point me in the right direction. I'm totally out of thoughts.
Old Apr 6, 2011 | 08:37 AM
CCA4's Avatar
Sounds like you've got a good start to troubleshooting this one. I'm at work right now but when I get home this evening I can take a look at my relay panel for ya
Old Apr 9, 2011 | 04:15 PM
Alright here's an update,I finally got the rear wiper to work after ordering a new #389 relay. Number 3 relay on plate #2 is suppose to be blank as pictured in my repair manual. Now all my wiper jets work execpt for the rear. I've got a new wiper motor in there so I know its not a clogged jet. I pulled the hose off the wiper motor an put hose in a bucket then closed my hatch an hit the switch for the washers which gave me no washer fluid in the bucket. The washer system worked before changing to a new motor. I then removed the new unit an replaced it with the old unit an the washer doesn't work. It makes no sense lol. Got wiper but no washer. I didn't see any leakage what so ever either.
CarpyDog
Oct 26, 2010 03:22 AM
tdiman
Jan 1, 2009 03:49 PM
piledriver
May 16, 2008 05:25 PM
gordond
May 9, 2008 03:10 PM
a4vt
Jun 22, 2006 06:17 PM
