removing lower strut screw from bushing?
Old Jun 10, 2014 | 09:46 AM
nlinesk8s's Avatar
Default removing lower strut screw from bushing?
Hi All,
I'm doing new wheel bearings and upper control arms (2000 A4,B5, ATW, quattro, fyi) Thanks to PB Blaster and a BFH, the pinch bolt came out fine. (no small miracle for Ohio)
However, the strut screw/bolt in the lower control arm is stuck in the bushing; the nut came off fine. I don't want to twist the bolt too much, for fear of ripping the bushing, but I have to get the strut out. Heat doesn't seem to be an option, but I might be wrong.
Anyone have any neat tricks for this? I may try to move the rear arm out of the way so I can whack the screw with a hammer, or at worst case break out the sawzall and cut the bottom U of the strut.
Those are the overwhelming force options, but I'd hate to miss a neat tool or method that would do this without cursing.
thanks,
Old Jun 10, 2014 | 10:17 AM
bshusted's Avatar
You may want to prepare yourself to replace the front lower control arm. Unfortunately, once the fastener gets stuck in the bushing tearing the bushing is sort of inevitable. I would guess that your best chance for saving the bushing would be to remove the control arm, strut still attached, and take the whole thing to a press. The key is going to be supporting the inner sleeve while pressing the bolt out.
ImSoSkrood
Jan 11, 2015 09:48 PM
samm86
Apr 29, 2011 01:29 AM
Audipotential
Sep 22, 2007 02:19 PM
timbo108
May 11, 2007 08:47 PM
haveaseat
Jun 14, 2006 01:02 AM
