Replace CV boot or Axle?
Old Jul 4, 2011 | 07:20 PM
  #21
KoolMan's Avatar
I'm happy.
So after 3 hours of cleaning the grease and everything in there the abs light went away.
There was grease in the cylinder that goes into the side of the caliper that hits the ring. So I think that may be all that was wrong hope it doesn't come back on anytime soon. I'll post some pics later so you Guys can see
Metalman I'll probably need some help from you later I'm thinking of putting a symphony II in at a later point
Thanks for the help.
Old Jul 4, 2011 | 11:00 PM
  #22
MetalMan's Avatar
Glad your ABS light went away! And sure I'd be happy to help, I've done lots of electrical work. Although I haven't had much experience with anything other than aftermarket radios.
Old Feb 25, 2013 | 08:38 AM
  #23
01 Avant's Avatar
i just got done with doing an outer boot and of course, didnt pay attention to which way the spacers went on - i read online that the plastic spacer goes on first with the smaller side facing the engine and the metal curved one facing the joint. i then saw a photo showing them the other way around and was told that way also but didnt know if any issues would occur??? - i took the car for a ride after and no noises so idk
Old Feb 25, 2013 | 01:44 PM
  #24
CheckerBird's Avatar
After doing my brake job yesterday, I discovered torn boots too... fortunately it's on the small ends of the outer boots, so all the grease is still being contained within, and hopefully not much contamination getting inside there.
I'm hoping my outer CV joints are still good and serviceable inside, but if I do have to replace them, I've read in my searches here and other Audi forum sites that changing the whole axle assemblies is discouraged due to the 3rd party aftermarket axles being poor quality and not lasting nearly as long as OEM... and OEM axle assemblies are way expensive. Does that also apply to Meyle brand CV joints or axle assemblies (significantly more affordable than OEM)? Or is Meyle good to go on their axle assemblies and CV joints?
Old Feb 27, 2013 | 11:37 PM
  #25
01 Avant's Avatar
so does anyone know if you put the spacers on backwards, what would the end result be?
biocpu
Feb 13, 2012 04:28 PM
sa9023
Dec 21, 2010 07:41 PM
chickeneater
Dec 7, 2010 12:41 AM
gedas429
Aug 28, 2009 03:19 PM
audi_lade
Feb 10, 2009 10:42 PM
