Replace hub and bearing or just bearing?
Old Aug 25, 2010 | 11:37 AM
A4 2000's Avatar
I don't know, but what makes me more sure that it's the passenger side bearing is that metal on metal crinkling sound.
Old Aug 25, 2010 | 11:50 AM
onepoint8tee's Avatar
A metal crinkling sound is not typical for a bad wheel bearing, either. It should sound like a gyrating or constant groan, moan, or grind if bad enough. Not so much a metalic sound.
Do you think a recorded drive-by might let us hear this sound?
Old Aug 25, 2010 | 02:24 PM
A4 2000's Avatar
I do get that gyrating sound from inside but it's hard to tell which side it's coming from. I'll try to do a video too see if I can capture the crinkling sound from the outside. But what else could be making that noise if it's not the brakes?
Old Aug 25, 2010 | 02:32 PM
Good question which is why I'd like to hear it. Maybe we have different definitions of what "crinkling" sounds like.
Old Aug 26, 2010 | 02:22 PM
A4 2000's Avatar
One thing I'd like to know is how does everyone else diagnose which side has a bad bearing. Or do you just replace both regardless? This is causing way too much stress for me lol. I feel like a wheel is going to come flying off or something ha, ha.
Old Aug 19, 2012 | 02:51 PM
ColoradoAudiDriver's Avatar
Hi--I know this is a thread that ended 2 years ago, but I'm wondering how this issue was resolved and if A4 2000's new bearings cleared it up. I have symptoms on my 2002 A4 3.0 V6 that sound very similar. Thanks!
Old Aug 19, 2012 | 04:35 PM
z28pete's Avatar
Have you checked the splash shield next to the rotor? Those things can easily bend when doing a brake job, or can get debris stuck between the shield and the rotor causing horrible grinding noises.
Old Aug 20, 2012 | 01:03 AM
  #18
A4 2000's Avatar
It was the passenger side bearing. The hub was pretty worn so I 'm gl.ad I had a new one ready. The shop did end up bending the plate too and it made a scraping sound. I just bent it back into place when I got home but they were such idiots that they had no idea where the noise was coming from.
Old Aug 20, 2012 | 03:19 PM
  #19
I'm probably going to be chastised out of this forum for reporting on this. Took the A4 to a dealer and they said it was lower control arm boot that was worn and ball joint lubrication gone. That was going to be $450, but they said more impending issue was upper control arm bushings that needed immediate replacement. $750 for that repair. I'm having it done for piece of mind, but wondering if I should've gotten a second opinion. A couple reputable independent shops in my area were too booked to even look at it. Should I stay clear from Audi dealer servicing in general? Or trust that they know Audis well...
Dallas09
Jul 20, 2008 04:20 PM
882DC
May 23, 2008 11:28 AM
cdmx
May 25, 2007 11:31 PM
aRIf
Feb 2, 2006 08:55 PM
