Replacement of Oil Cooler Hoses?
Old Feb 6, 2008 | 02:36 PM
A4fiastein's Avatar
Default Replacement of Oil Cooler Hoses?
I have an 8 year old Audi a4 1.8T. with about 89,000 miles. Went in for the 90k maintainence and they said I needed to replace oil cooler hoses due to leaking antifreeze.
The cost $525!!
FYI I' always kept up on the maintainence.
Looking for thoughts on if this is a decent price and is this something that should be done considering the number of years and mileage.
Thanks!
Old Feb 6, 2008 | 03:51 PM
99A4NOW's Avatar
Default RE: Replacement of Oil Cooler Hoses?
These hoses arecheap, less than $10 a piece from ECS Tuning.
http://www.ecstuning.com/stage/edpd/...tegory=Cooling
You should be able to handle it yourself, but you'll need to drain the coolant and then fill her back up when you're finished. If someone is asking over $500 to do this job ask them to show you exactly what they're doing for that kind of money.
Old Nov 16, 2016 | 03:03 AM
OldAudiA4B5's Avatar
Does a shitload of coolant spill out if / when you disconnect these hoses?
Old Nov 16, 2016 | 01:57 PM
hartsoe1's Avatar
not if you drain it first as stated above.
Old Nov 21, 2016 | 02:54 AM
Does anyone know approx. how many litres come out disconnecting these hoses?
Old Nov 21, 2016 | 02:44 PM
elduderino200's Avatar
How many liters of coolant? Likely all of them.
If you haven't changed out your coolant in a while, get two bottles of g12, a couple gallons of distilled H20 and just replace everything when you do your hoses. Cant hurt.
BernieApshago
Mar 16, 2014 08:13 PM
vtraudt
Jul 18, 2012 01:11 PM
keefboz
Nov 18, 2008 07:28 AM
A4fiastein
Feb 6, 2008 03:51 PM
GregaXX
Apr 19, 2005 09:44 AM
