Replacing head gasket - what mods should I do?
Old Jun 16, 2008 | 10:21 PM
pimphell's Avatar
Default RE: Replacing head gasket - what mods should I do?
ORIGINAL: cincyTT
ORIGINAL: pimphell
I think that you should have the head flowed and port and polish everything. That will make it live a little
You dont know what head he is using nor power level. A stock AEB head doesnt really need a port job and he wont see real gains porting a small port to big port on a sub 300whp car.
Why do you insist on trying to bash me?
Old Jun 16, 2008 | 10:30 PM
pimphell's Avatar
It's simple advice, the head is off anyways?
Old Jun 17, 2008 | 01:30 AM
turbo kraut's Avatar
Tech Guru
ORIGINAL: pimphell
ORIGINAL: cincyTT
ORIGINAL: pimphell
cause more $hit comes out of your mouth than out of my a$$, and i $hit everyday
lurk on the forums and learn before you spew nonsense
Old Jun 18, 2008 | 11:19 AM
Mike-2ptzero's Avatar
ORIGINAL: spwilkins
I bought this car with the head off, the timing belt wiped out, and every valve bent. If I want to have a little fun, thats not too expensive, what modifications should I consider whenputting this thing back together? Also, aftermarket valves are alot cheaper than Audi parts - why?
You didn't happen to buy that car in CA?
You have to watch out when ordering aftermarket valves, not all of them are up to stock standards and not all OEM style exhaust valves are filled.
For a little more money I would suggest paying a little more money for a set of 1 piece inconel exhaust valves which cost around $29.50 each vs $22 for a stock version.
Old Jun 18, 2008 | 11:31 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: turbo kraut
ORIGINAL: pimphell
ORIGINAL: cincyTT
ORIGINAL: pimphell
Thats a pretty good sumation. BTW, that was FAR from bashing. As for this car, if you are stock and dont plan on much more than that, stock parts will be best unless you want to shell out for what mike recommended. About the only gain you could see is some NA cams but are hard to come by and still not worth the small gain
Old Jun 18, 2008 | 05:24 PM
01afour's Avatar
yeah i think a question like this all comes down to how much $$ you got and what your goals are. we got the goals, just a 'trick' or two, but how much do you have to spend?
i gotta agree w/ cincy on this one, a port and polish is pretty useless if thats all you do. ive looked at the inside of the head that i took of my car and the walls seem pretty clean and theres no point in porting it to fit up to a stock intake mani and turbo. if you wanna go all out i would do a 3 angle valve job, some cams and nice strong valves and you should see a little difference. but like others have said, not much on a low hp car.
Old Jun 19, 2008 | 03:01 PM
pimphell's Avatar
So your telling me that a simple port and polish and maybe flow the head wouldn't be worth it on the stock engine. Where have you got an education? Opening up the head makes a difference in any car, especially a turbo car. Even in lower hp levels and of course your going to see a better gain with the rest of the engine being built up on higher hp levels. come on now
Old Jun 19, 2008 | 04:20 PM
  #18
rsrbljan's Avatar
Look, if he's planning on a~250 WHP car, the head is not the most restrictive portion of the engine. Hence you will see little gains from portingthe head. spend about 20 hours gasket matchinga head and then get 2hp on a dyno... tell me it's worth it. if you're not utilizing 100% of the head's flow, increasing that potential to 110% makes no differance.
The flip side is if you're building a 500hp motor,if you gain10% in flow through the port job it equates to a significant gain on a large power build...
If i'm hearing cincy right, he's not saying it does nothing, he's saying there are no potential gains when the flow of the head is not the bottleneck. I agree with that statement.
Ryan
Old Jun 19, 2008 | 04:28 PM
  #19
01afour's Avatar
ORIGINAL: pimphell
for the money...on a car w/ less then 300 hp this would be useless. of course he can go and spend the money on that, but you wont see much of a difference. if you look at the stock head, its pretty damn smooth in there so a polish wouldnt do much, and if you port it, with the stock intake mani theres not gunna be much more airflow, because the mani is still the same size. what are you not getting about that? if the guy wants to spend money on porting and polishing a head to gain under 5 hp then thats fine, but he wants to kno what would be worth it and what would make a difference, therefore a port and polish job is basically useless.
he can save the few hundred bucks and chip it and see a way bigger difference.
Old Jun 19, 2008 | 04:32 PM
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: pimphell
A "simple" port and polish is still far from cheap and will only net a very minimum gain on a stockish car. The large cost for very small gain is not worth it. I like how you ? my education and you come on here and post BS all over the place. I think the more you talk, the more Turbo Kraut looks right
