Quote:
I have the 034 street density and they are great! Took a little time to break them in, but once they did they are exactly what i was looking for. Don't rattle your brains out, but definitely stiffen up the drivetrain.Originally Posted by CCA4
That's what I was planning on going with. Nothing too crazy, and I'd heard the Stern softs were actually pretty bearable, especially compared to 034's track density mounts. I feel like RS4 mounts are overpriced for what you're getting...
Quote:
What clutch are you runnin again? Is it tough to drive in traffic?Originally Posted by FASTER
The only time I ever get a chatter is if i rev it with out the clutch in, it will chatter on the rpm drop. And my flywheel is 9lb billet aluminum.
Moderator
WOW 9 pounds and it doesn't chatter? Did it chatter when it was new?
Definitely glad you put this up. This is the exact clutch I'm planning on getting, already have a SMFW in so sounds like it should be pretty easy to adapt.
Also idk why anyone wouldnt get the 240mm, definitely worth a little extra for the clamping power.
If you wanna go with this clutch package I really think you'll like it. The only reason I can think of that you WOULDN'T want the 240mm upgrade is for a racing situation. The larger diameter flywheel/clutch would take longer to shift in a drag racing situation but for a street setup it's very good.Originally Posted by meloman
Definitely glad you put this up. This is the exact clutch I'm planning on getting, already have a SMFW in so sounds like it should be pretty easy to adapt.Also idk why anyone wouldnt get the 240mm, definitely worth a little extra for the clamping power.
