Review: Clutch Masters FX-300 240mm and 17lb steel LWFW
Old Aug 2, 2012 | 12:30 PM
shortyxc's Avatar
Originally Posted by CCA4
That's what I was planning on going with. Nothing too crazy, and I'd heard the Stern softs were actually pretty bearable, especially compared to 034's track density mounts. I feel like RS4 mounts are overpriced for what you're getting...
I have the 034 street density and they are great! Took a little time to break them in, but once they did they are exactly what i was looking for. Don't rattle your brains out, but definitely stiffen up the drivetrain.
Old Aug 3, 2012 | 07:04 AM
FASTER's Avatar
Tech Slut
The only time I ever get a chatter is if i rev it with out the clutch in, it will chatter on the rpm drop. And my flywheel is 9lb billet aluminum.
Old Aug 3, 2012 | 07:22 AM
CCA4's Avatar
What clutch are you runnin again? Is it tough to drive in traffic?
Old Aug 3, 2012 | 07:54 AM
jonbonesjones's Avatar
Moderator
WOW 9 pounds and it doesn't chatter? Did it chatter when it was new?
Old Aug 3, 2012 | 08:39 AM
FASTER's Avatar
Tech Slut
Now a werk of art custom dual diagram with a CM sprung hub 6 puck. But I've had this flywheel with a few other clutches.
Old Aug 4, 2012 | 11:23 AM
meloman's Avatar
Definitely glad you put this up. This is the exact clutch I'm planning on getting, already have a SMFW in so sounds like it should be pretty easy to adapt.
Also idk why anyone wouldnt get the 240mm, definitely worth a little extra for the clamping power.
Old Aug 4, 2012 | 10:16 PM
CCA4's Avatar
If you wanna go with this clutch package I really think you'll like it. The only reason I can think of that you WOULDN'T want the 240mm upgrade is for a racing situation. The larger diameter flywheel/clutch would take longer to shift in a drag racing situation but for a street setup it's very good.
Mike-2ptzero
Sep 10, 2015 12:16 AM
Mike-2ptzero
Jan 14, 2010 04:03 PM
Mike-2ptzero
B7 Models
Jun 2, 2009 02:44 PM
Mike-2ptzero
May 30, 2009 07:17 PM
Mike-2ptzero
May 26, 2009 06:48 PM
