right way to disconnect battery?
Old Nov 10, 2008 | 01:43 PM
iheartboost's Avatar
Default right way to disconnect battery?
so i just got my car back from the shop getting the throttle body recalibrated. it got misaligned the last time i disconnected the battery. so my question is why did this happen this one and only time, ive disconnected the battery countless times and have never had a problem.
could it have happened because i disconnected it with the key off, and then reconnected it with the key turned on? thats the only thing i can think of...
im just scared to disconnect the battery again.
Old Nov 10, 2008 | 01:48 PM
euro_2nr's Avatar
Pull negative first and plug negative last. Never leave your key on either way.
Old Nov 10, 2008 | 02:05 PM
airguard350's Avatar
Tech Guru
^ I second that.
Old Nov 10, 2008 | 02:23 PM
relliMmoT's Avatar
i believe the negative first thing is primarily a safety concern to prevent arc.
Old Nov 11, 2008 | 01:12 AM
Tweaked's Avatar
Or to prevent turning yourself into a human fuse...
Old Nov 11, 2008 | 10:40 AM
Mike-2ptzero's Avatar
Just make sure that when you do disconnect the batter, always turn your key on for 30 seconds after you reconnect the battery. This allows the ecu to do a throttle adapt and store that info.
Old Nov 11, 2008 | 10:49 AM
Jc61990's Avatar
how can you pull the negative twice?
Originally Posted by airguard350
^ I second that.
no you dont
Old Nov 11, 2008 | 10:52 AM
Jc61990's Avatar
nvm... im an idiot. i just woke up so i thought u said pull twice. didnt realize one said plug... so then yea i agree with what euro_2ner said
Old Nov 11, 2008 | 04:22 PM
A4 Effort's Avatar
You know you can do a Throttle Body Adaptation, correct?
1) Push the gas pedal all the way to the floor
2) Turn ignition on for 20-30 seconds (do not start)
3) Turn ignition off, release gas pedal
4) Start car and go for a spin
Old Nov 11, 2008 | 04:36 PM
NEVER ever press the gas pedal while doing a throttle adapt.
