right way to disconnect battery?
Old Nov 11, 2008 | 06:43 PM
Darkprodo's Avatar
Originally Posted by Mike@DTH
NEVER ever press the gas pedal while doing a throttle adapt.
other than using the scan tool... driving it for about 30 minutes its supposed to re-adapt it. but the problem is, if there is a fault related to the throttle body module most likely it won't go thru.
you want in on a little dealer secret...?
start the car... and remove the battery while the car is running.
you won't loose TB adapt, pinch protection, or even have to reset the clock.
just make sure you have the replacement battery ready to go in.
Old Nov 11, 2008 | 06:44 PM
A4 Effort's Avatar
^esplain'
Old Nov 11, 2008 | 07:04 PM
Darkprodo's Avatar
Originally Posted by A4 Effort
^esplain'
car will run off the alternator...
people are often confused about the alternators purpose. they think its to charge the battery and the car runs off of the battery.
car runs off of the alternator. the battery is used for starting and reserve power. yes, the alt does charge the battery but its not it primary function
Old Nov 11, 2008 | 07:41 PM
Mike-2ptzero's Avatar
30 minute of driving will adapt the fuel trim adjustments not the throttle adapt. The ecu goes thru a throttle adapt the first time the key is turned on after the battery has been disconnected. If you do this you can actual hear the throttle going thru a cycle for the throttle adaptation. I used to do a throttle adapt a few times a week and once after swapping in a new chip while at the drag races every single weekend for the first 2 years of the 8 years I have been drag racing the 8 years.
Old Nov 12, 2008 | 10:34 AM
Tweaked's Avatar
Wait, what dealer do you work for?
Old Nov 12, 2008 | 11:02 PM
gabe711's Avatar
+1. test drove a honda once which had no battery in it, got my friends truck, used some power cables to start the car and used it for about some good 3 mins i say till it died on us
YorkshireAudiA3
May 20, 2015 08:18 PM
inventorA6
Apr 16, 2010 06:18 PM
04A6RGR
Oct 22, 2008 11:41 AM
jandouglass
Jan 2, 2008 05:18 PM
shabbey
Sep 28, 2004 01:23 AM
