Rims again
Old Jan 20, 2014 | 07:37 AM
rmr1499's Avatar
Default Rims again
Yes I know another rims thread. Ok we'll looking to order some rims for the 00 b5 1.8tqm I'm lookin at some replica rims I can get threw my work I'm going 17in with 225/45/17s there a few choice but there's one set idk what it comes from and if it will fit it's a 17x7 with a 45 offset will this work the other set is a 35 offset I know that will work and there is a 40 offset I dunno if will fit either but I want to be able to run without spacers what do you think
Old Jan 20, 2014 | 03:36 PM
rmr1499's Avatar
anyone
Old Jan 20, 2014 | 04:25 PM
MetalMan's Avatar
I run 17x7.5 et35 with 225/45/17. If your pretty low, you'll need the front fenders rolled. I'm moderately low (~2" drop) and my front fenders are NOT rolled, but every once in a while I hear a tire scrape. It's no big deal.
Old Jan 20, 2014 | 05:02 PM
rmr1499's Avatar
It's gunna have stock springs and Blau struts no lowering no thank you lol
Old Jan 22, 2014 | 10:29 AM
rmr1499's Avatar
Anyone?
17x7s with a 45offset with 225/45/17s with stock springs and Blaustruts which are the same height as oem
Old Jan 22, 2014 | 10:54 AM
MetalMan's Avatar
What's the question? Will it work? Yes, it will. The S4 came with 17x7.5 ET45 and 225/45/17.
Old Jan 22, 2014 | 12:40 PM
rmr1499's Avatar
So that should fit with no rubbing and no spacers needed? Cause I'll never use spacers
Old Jan 22, 2014 | 01:39 PM
MetalMan's Avatar
Read my post above yours, the answer is there.
Old Jan 22, 2014 | 02:03 PM
rmr1499's Avatar
No I saw that you said it will fit I just wanna make sure it will without spacers
Old Jan 22, 2014 | 04:37 PM
MetalMan's Avatar
The S4 doesn't come with spacers, and your suspension (minus springs and shocks) is the nearly the same as a S4. Therefore yes, it should fit without spacers.
