rod knock
You arent running your engine anymore, right?
Get a pic of your injectors while your at it so we can determine if they are stock or not. Did your car come with the GIAC chip, or did you get that after you bought it?
no im definetly not driving it. it wouldnt even drive if i wanted it too.
i put the chip in like a little before last christmas.
http://i107.photobucket.com/albums/m...9/injector.jpg
Are you able to contact the original owner? Those don't look stock, at all. I'd be surprised if someone put in big injectors without a bigger turbo or at least a tuned ECU. Your turbo is a stock k03 right? Did you notice a big improvement when you got chipped? Is your fuel pressure regulator stock?
i have a stock turbo, i noticed a pretty big difference with the chip. im pretty sure the fuel pressure regulator is stock. wat would bigger fuel injectors do?
im gunna call the guy i bought the car off
i have the valve cover off, and it looks like its gunna be a nightmare to get the head off. idk where the timing marks are or anything. do you know where i can get like an exploded view of my motor?
The timing mark is on the valve cover, if you don't wanna mess with the timing just use some channel locks and clamp the belt to the cam sprocket, remove the cam sprocket from the head and use a bungee cord to hold it against the radiator. This will eliminate a few hours of work.
