SAI system delete
Old Jan 25, 2011 | 12:59 AM
mschneidie's Avatar
Default SAI system delete
Anybody here taken out their secondary air system. Mine's been acting up, and I want to run intake and intercooler piping through the area anyways. Any way that I can get the CEL deleted?
Old Jan 25, 2011 | 06:40 AM
ImTheDevil's Avatar
You can but if you have any sort of emissions component (ECU code scan) in your inspection, you'll fail. Search feature will turn up a bunch of info on who sells a kit to delete it.
Old Jan 25, 2011 | 09:24 AM
dragonrage's Avatar
Things you'll need:
-A tuned ECU with the SAI codes removed... I got mine from k0mpressed
-Integrated Engineering SAI blockoff plate or similar
-A couple of large fender washers with a ~2" bolt and nut that fit between them
-Some sort of sealant, be it silicone adhesive, RTV, epoxy, etc.
Steps:
-Install tuned ECU
-Remove your kombi valve and everything connected to it and put the blockoff plate right on the engine block.
-Pull the SAI line from your airbox
-Put one washer on the inside and one on the outside of the new hole in the airbox and bolt them together
-Seal around the washer on the outside with RTV/whatever
-Remove the actual SAI pump (optional but recommended) - it's at the lower right just behind your front bumper
-Reroute vacuum lines around the SAI solenoid under the intake manifold (for 1.8s, anyway... not sure where it is for 2.8s) - my vaccum setup is attached.
Old Jan 25, 2011 | 10:28 AM
ImTheDevil's Avatar
Offhand do you know which companies offer the delete? I don't have much to gain with a chip on my 30v but I wouldn't mind deleting the system altogether before it has an issue.
Old Jan 25, 2011 | 11:22 AM
CCA4's Avatar
I know Mike Hood sells the blockoff plate, not sure who else?
Old Jan 25, 2011 | 11:25 AM
turbo kraut's Avatar
Tech Guru
he is talking about companies that can write the code for him i think
Old Jan 25, 2011 | 11:30 AM
dragonrage's Avatar
Unitronic does it for some years. Actually, they do it for 2001, so OP can use them.
Old Jan 25, 2011 | 11:42 AM
Mike-2ptzero's Avatar
Yes I do. I sell the IE block off plate and have a few of them sitting right here. The ones I have are the older ones that are not anodized.
Yes Unitronics does offer removing the SAI code on their tunes.
Old Jan 25, 2011 | 12:13 PM
CCA4's Avatar
gotcha, you're right. Reading post FAIL.
Old Jan 25, 2011 | 02:03 PM
cantdrive55's Avatar
Does GIAC offer the SAI delete or a test pipe file?
