Secondary Air Injection Pump
So I keep pulling codes relating to the secondary Air injection pump flow being low for both banks 1 and 2. Do you guys think this is just the pump needing replaced or a line or something else?
Thanks
Jeremy
Thanks
Jeremy
I suggest changing all the vacuum lines and checking the hoses going directly to the pump. Hearing the pump come on at least is a good sign. Clear the code and see what happens. If it still comes on then you might need a new egr valve.
i just had my SAP replaced last week, because it would run on off whenthe car was off and killed my battery. now with the new one i found after 25 miles or so and then the car is off for a while it turns on at startup but dont shut off. i end up pulling the plug on it, drive home 25 miles plug it back in and its fine. any idea???
T-Wall
Apr 12, 2012 12:33 PM
