secondary air injector pump
Old Dec 28, 2012 | 10:27 AM
tpkg's Avatar
Smile secondary air injector pump
Hello Guys!
Happy holidays to you all!
I have an issue that when I turned my engine off still the whinny sound comes from the passenger side under the air filter that drained my battery over night.
I researched that the sound might be the secondary air injector pump.
some of the guys say that the Secondary air injector pump is not necessary to have unless i do care about the engine light.
does anyone know that if I disconnect the SAI it will hurt my car?
What I've been doing is that I disconnect the battery at night and connect the battery in the morning.
disconnect and connect everyday will it hurt my car?
Please let me know Thank you guys.
Old Dec 28, 2012 | 02:00 PM
CCA4's Avatar
I removed my SAI pump a few weeks ago and haven't had any issues. You'll get a CEL but it can be fixed without too much trouble
Old Dec 29, 2012 | 12:18 PM
tpkg's Avatar
If I unplug the pump would it be okay as well?
let me know
this thing bothers me so much!
everyday i have to disconnect and connect my battery!
Old Dec 29, 2012 | 12:23 PM
CCA4's Avatar
Yeah just unplug it. You'll get a CEL and one or two codes but it's better than draining your battery every night.
Old Dec 30, 2012 | 11:11 PM
tpkg's Avatar
just for my curiosity if i disconnect my battery everyday does it hurt my car?
Thank you!
Old Dec 31, 2012 | 08:12 AM
CCA4's Avatar
Doesn't hurt the car really, but it's definitely a pain in the ***. The mileage in the odometer is stored in the gauge cluster and won't be affected by the battery being unplugged. Why not just unplug the pump and forget about it?
Old Jan 3, 2013 | 12:17 AM
tpkg's Avatar
Do I simply unplug the SAIP ?
Is that all I need to do?
Thank you
Old Jan 3, 2013 | 12:32 AM
tofast2belast's Avatar
Thank you
yes, you can put a 1 ohm 10 watt resistor in the connector and you wont get the cel.
unplugging the battery does affect the car. it resets the readiness modules, so if per say you you unplugged the car and went to take it in the next day for emissions and inspection, you will fail emissions and be told to drive the car around for a few miles and bring it back.
also unplugging the battery resets fuel trim adaptations. so the ecu will keep having to relearn your driving habits. thus may hurt fuel economy.
Old Jan 3, 2013 | 07:27 AM
jonbonesjones's Avatar
Moderator
youll only solve 1 code with the resistor. Youll get two codes when you unplug the pump 1 for it being unplugged and 1 for it not doing what its supposed to aka - incorrect flow code. You need a chip to solve that.
Old Jan 3, 2013 | 11:56 AM
redmond1501's Avatar
Leaving the battery unplugged long enough can throw off the throttle body alignment setting. The car will idle badly if this happens.
