Secondary electric fan problems
Old Jun 3, 2011 | 01:48 PM
jimmygiggles's Avatar
Default Secondary electric fan problems
I just replaced the whole fan unit, (after testing with direct power and fan not working, went to wreckers and bought new unit which powers up fine with 12 volts), turn the car on with ac and nothing, checked the 40 and 5 amp fuse, both ok, removed the thermo switch wiring harness, tried jumpering both (brown to red for low.. etc. I can hear the relay clicking, but power not going to the fan)
Now, where is that relay located, and is there 2 relays? or just one. anyone had this problem before??
Just an update, problem was with actual harness, push the wires more in, and voila, got the high speed to run when jumpered, low speed won't run when jumpered now, atleast im getting power now
I guess the low speed relay is gone.. where is that located??
Thank,
Tony
Old Jun 6, 2011 | 09:01 PM
anybody know where that low speed relay is located??
Old Jun 6, 2011 | 10:18 PM
Tweaked's Avatar
What year and engine B5?
Old Jun 7, 2011 | 08:43 AM
ImTheDevil's Avatar
In the stickies at the top of the forum there is a relay panel breakdown. That should show you where it is.
Old Jun 7, 2011 | 03:00 PM
99 1.8T. AEB.. and i looked on that sticky.. i didn't show the relay.
Tony
Old Jun 7, 2011 | 08:57 PM
Tweaked's Avatar
You replaced the fan, but did you replace the fan control unit? I can't remember if a 99 has one...
Old Jun 8, 2011 | 08:32 PM
Well, I will be getting a bentley tommorow for my car.. I have no idea if I have that either
Guess I will see when I get the bentley.
Tony
Old Jun 9, 2011 | 12:33 AM
DOC_DEPALMA's Avatar
Keep your head up buddy
Old Jun 9, 2011 | 03:40 PM
heh.. didn't realise how big this service manual would be. found it on kijiji in almost mint condition for $10
jcude16
Nov 25, 2011 05:52 PM
a4one
Aug 4, 2009 06:00 AM
TheBat
Jun 18, 2008 02:42 PM
garyl
Aug 25, 2007 10:29 AM
powerplant
Dec 1, 2006 10:02 AM
