Sedan Vs. Avant Coilovers
Old Feb 13, 2008 | 05:27 PM
feerocknok's Avatar
Default Sedan Vs. Avant Coilovers
H&R part numbers for their standard coilovers are:
29591-3 for Sedans
29591-4 for Avants
which can lower the front between 1.6" and 2.5", and the rear 1.3" and 2.0".
H&R also makes a set of Ultra-low coilovers, but only have a sedan part number:
50011-1
which can lower the front between 2.0" and 3.0", and the rear 2.0" and 3.0".
I called H&R, and was told that they wouldn't interchange, but didn't recieve an answer as to why, besides that the part numbers are different.
Besides spring rates and possibly valving rates, will the 2 interchange?
Old Feb 13, 2008 | 06:19 PM
ImTheDevil's Avatar
Default RE: Sedan Vs. Avant Coilovers
Greater weight on the rear of the Avant may have necessitated different suspension geometry, and therefore maybe slightly different parts back there, which would interfere with the mounting of the springs. I don't know, but other than spring strength, that's the only thing I can think of.
Old Feb 13, 2008 | 06:37 PM
feerocknok's Avatar
Koni doesn't distinguish between the two with their shock or coilover kits. I just don't wanna dump almost 2 grand into coilovers that might bolt up.
Old Feb 13, 2008 | 07:20 PM
Lazer Viking's Avatar
why dont you just buy the ones for the sedan, so you know they fit ?
Old Feb 13, 2008 | 09:40 PM
sineo's Avatar
ORIGINAL: Lazer Viking
I'm guessing he's not sure they'll fit his Avant [8D].
Old Feb 13, 2008 | 09:59 PM
damn ! i've been dooped, nvm.. i thought he had a sedan
so then, why dont you just buy the ones to fit an AVANT
Old Feb 14, 2008 | 02:14 AM
feerocknok's Avatar
They don't make Ultra Lows for Avants.
Old Feb 14, 2008 | 10:36 AM
chaos92287's Avatar
i doubt they're interchangeable cause of the avants extra weight. but if Koni doesn't distinguish between the two, i would give them a call instead and ask if their interchangeable, you might get a clearer answer
Old Feb 14, 2008 | 11:32 AM
im pretty sure they will work
there was some guy that bought used ultra lows on audizine, and put them on his avant
Old Feb 14, 2008 | 01:52 PM
feerocknok's Avatar
Good thinking on calling Koni! That may be the answer.
And LV, I'll search audizine, thank you for the tip!
