semi-big problems guys
well to start off, after drivign for about 10 mins, and the motor is warmed up, when i come to a stop, i hear a very loud ticking noise coming from under the hood, but when i start to drive, it goes away. i have read that this could be a bad oil pump / screen... but how valid is that?
Also, i have no boost what so ever... i have a VDO boost gauge and the APR tune, i used to get 17psi... now im lucky if i get 3psi... any ideas guys?
also i need to do the timing belt. so if indeed my oil pump/screen need to be replaced im gonna do that at the same time
2000 A4 1.8TQM
2000 A4 1.8TQM
No boost means that your engine is in safe mode, most likely due to a previous overboost condition. Have the codes pulled and clear them. That should at least get your boost back.
The alternative is a massive boost leak, so check the hoses.
I had a retard clatter-clatter-click-click noise at lower RPMs a couple weeks ago
turned out that Audi of Santa Monica didn't tighten the bolts down after the timming belt job
out of the 6 that were supposed to be on there, 3 had fallen out and were missing, and the other three were loose as fu<k....luckily I caught it before my motor was taken to the dome...lol
sounds like your car is in safe mode...get the codes cleared and you should be good, boost wise
numlock4045
Jan 26, 2012 11:46 PM
