semi-big problems guys
Old Feb 19, 2008 | 05:47 PM
LuckyCharmsUXZ's Avatar
Default semi-big problems guys
well to start off, after drivign for about 10 mins, and the motor is warmed up, when i come to a stop, i hear a very loud ticking noise coming from under the hood, but when i start to drive, it goes away. i have read that this could be a bad oil pump / screen... but how valid is that?
Also, i have no boost what so ever... i have a VDO boost gauge and the APR tune, i used to get 17psi... now im lucky if i get 3psi... any ideas guys?
also i need to do the timing belt. so if indeed my oil pump/screen need to be replaced im gonna do that at the same time
2000 A4 1.8TQM
Old Feb 19, 2008 | 06:36 PM
david9999's Avatar
Default RE: semi-big problems guys
No boost means that your engine is in safe mode, most likely due to a previous overboost condition. Have the codes pulled and clear them. That should at least get your boost back.
The alternative is a massive boost leak, so check the hoses.
Old Feb 19, 2008 | 08:30 PM
The Bishop's Avatar
Also check your fuses. That happened to me and it turned out to be the ecu fuse.
Old Feb 19, 2008 | 09:11 PM
well i pulled the codes and cleared them. and i have my boost back. thanks so much for that
but as for the ticking noise... do u think it is the oil pump / screen?
Old Feb 19, 2008 | 09:33 PM
auditech79's Avatar
If your car is sounding like a diesel engine i would have a shop check the oil pressure for you. If its low, then yes its probably your oil pick up tube thats clogged.
Old Feb 20, 2008 | 02:18 PM
qUaTtRoA4's Avatar
I had a retard clatter-clatter-click-click noise at lower RPMs a couple weeks ago
turned out that Audi of Santa Monica didn't tighten the bolts down after the timming belt job
out of the 6 that were supposed to be on there, 3 had fallen out and were missing, and the other three were loose as fu<k....luckily I caught it before my motor was taken to the dome...lol
sounds like your car is in safe mode...get the codes cleared and you should be good, boost wise
numlock4045
Jan 26, 2012 11:46 PM
crazyone
Aug 8, 2011 12:20 AM
guru_king423
Jun 17, 2008 08:15 PM
Kingjon
May 31, 2005 07:37 PM
