Serious confusion.
Old Oct 22, 2013 | 06:30 PM
WhosJbags's Avatar
Default Serious confusion.
First of all its a 98' 2.8 115k on it. Not new to the Audi scene, I've just never had this happen before (with any cars of mine at all.)
Here's the scenario....
Went to a carnival with a few friends, car drove fine. Drove home... still fine. Wake up the next day to go to work, and on my way to work the car started shaking and juttering. Almost like it was being starved for fuel. Go to slow down for the stop, put it into neutral and it just dies right out. Started it back up, turned over perfectly fine. Continued on my way, same exact thing happened. Finally got it to turn over, then nursed it home.
To me, automatically right off the bat I would assume fuel pump/filter(if that is the problem). But my OB2 machine didn't throw any codes for incorrect fuel, fuel levels, so on so fourth or anything along those lines. I do have a Fuel line/pump pressure tester (cant find it though.) I would just hate to have to cough up $300+ for a fuel pump and have it not be the issue.
Any suggestions or knowledge would be greatly appreciated!
Old Oct 22, 2013 | 06:47 PM
MetalMan's Avatar
Did the CEL flash while this was happening?
Old Oct 22, 2013 | 07:06 PM
WhosJbags's Avatar
Yeah CEL was flashing while it was happening
Old Oct 22, 2013 | 07:13 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
A flashing CEL, and your description, indicates that the car is misfiring.
Old Oct 22, 2013 | 07:20 PM
WhosJbags's Avatar
Does not throw any codes for misfires. Plus after the car has sat for about an hour - hour and a half. It will fire right up, but once it gets warm it dies right out. You have to feed it gas through the pedal or she wont even budge.
Old Oct 22, 2013 | 07:41 PM
WhosJbags's Avatar
Not shooting down that idea BaseDrifter, I'm open to all possibilities
Old Oct 22, 2013 | 09:49 PM
Mad Cow's Avatar
How warm are you talking about? Sometimes a coolant temp sensor can go bad and only show symptoms when the motor warms up a bit. Check the coolant temperature using an OBD scanner to see if it's in the right ballpark. Even if your gauge works perfectly, it uses a different thermoresistor on a different circuit.
ILoveSun
Oct 19, 2014 07:36 PM
ziglit123
Oct 28, 2008 05:25 PM
ilovelagar
Oct 21, 2008 11:33 AM
JJ Cleghorne
Dec 12, 2007 12:44 PM
dhirsty
Jul 3, 2006 11:34 PM
