Shaking while idling
For some reason when im idling my car begins to shake or shudder. It does not do it everytime i stop but only sometimes. If anyone knows what this is caused by and how i can fix it please let me know.
Typically when that happens to any vehicle, the RPMs are too low, for whatever reason.
You can either turn up the idle or keep the rpms up with the gas pedal (which will supply enough vacuum for the brakes without affecting the air/fuel mixture), or perhaps you just need to clean/replace your air filter.
Good luck.
Good luck.
You have a vacuum leak. My car did the same thing because the BOV wouldn't close all the way. At idle I was at -10 in drive for vac and the car would shake. When i got the bov to close, now I have -16 in drive and -19.5 in neutral and she runs very smooth.
Check the vac lines. If you don't have a boost gauge get one.
Josh
