Shifting issues
Old Sep 28, 2008 | 09:20 PM
Ramathorn's Avatar
Default Shifting issues
I recently purchased a 99 a4 2.8l quattro and i am in love with it. But i am now experiencing some jamming i guess with the shifter. while in neutral and i try and shift to third the shifter feels like it is hitting against a metal pole, them if a push it a little to the left it goes in. I also experience this a bit with first gear but i have to move it to the right a bit, but is no were near as bad as the third gear. Now would this be a problem with the shifter unit or would i need a tranny fluid flush, or is the problem worse.
Old Sep 28, 2008 | 09:23 PM
Jc61990's Avatar
might be the clutch
Old Sep 28, 2008 | 10:17 PM
Mike-2ptzero's Avatar
Any chance it has a aftermarket short shifter?
Old Sep 29, 2008 | 12:18 AM
ghost6303's Avatar
if it is stock, theres a few things you can do. one would be a trans fluid change, you could probably use one anyways and its something you should do when you first buy a car, and you can definately feel the difference between very old stock fluid and new high quality fluid like Redline or something.
second would be to replace your shift linkage, you can pull off your leather shift boot and see the plastic ball and cup that it sits in now, theres probably alot of play in there as the plastic wears down. i have a JHM solid shifter, its a night and day difference, simply amazing shifts, i cant remember the last time i missed a gear with this shifter.
worst comes to worst, something in the trans itself might be broken, but i would look at the other things first.
nwssinc
Dec 18, 2017 06:27 AM
MACattack
Feb 3, 2013 02:55 PM
WaWa
Mar 15, 2012 12:46 PM
jackson101
Jun 18, 2010 10:06 AM
Quattro11
Aug 26, 2004 02:53 PM
