CVT Shifting issues
Old Feb 20, 2012 | 06:51 PM
WaWa's Avatar
Default CVT Shifting issues
Hello i own a 2003 Audi A4 FWD with the CVT transmission, everything works fine on it but sometimes when i put it in the manual mode it won't shift up or down and that's only sometimes doesn't matter if the car is cold or warm or in between sometimes it works and sometimes it doesn't, any help will be greatly apprectiated
thanks
Old Feb 21, 2012 | 02:10 PM
WaWa's Avatar
bump can anyone please help me with this issue?
Old Feb 22, 2012 | 11:43 AM
pa4ul's Avatar
mine does that. Though im pretty sure it was a result of my gf spilling coke down into the shifter. I tried to clean it up but i think is seeped down into the shifter and causes my tip to not register unless i push on it with some force.
Old Mar 12, 2012 | 09:52 AM
USN_BMW22's Avatar
It's a sign that part of your transmission control module is failing. Stop putting it into manual before you kill the tcm and be stuck on the road bc your tranny won't shift at all.
Old Mar 12, 2012 | 11:46 AM
shipo's Avatar
"Manual"? We're talking about a CVT here; right? I guess I'm having a difficult time wrapping my brain around a "Manual Mode" as a component of a CVT.
Old Mar 12, 2012 | 02:11 PM
pa4ul's Avatar
let me ask u this before we can rule out usn bmw22 suggestion. When u put it in tip mode (shifting mode) do the gear numbers light up when u cannot shift or does it still say the normal prnd? IF ur gears numbers show but u cant shift then i would say its ur tranny. If not i woudl say ur tip mode is not engaging at the shifter and wouldnt be concerened with the transmission.
Old Mar 14, 2012 | 10:26 PM
Audi Tek's Avatar
Tech Certified
Pa4ul there is a printed circuit board on top of the shifter mechanism which probably shorted out. its easy to replace.... but probably a little pricey.
WaWa..... I would lead to think this is your problem as well. Aslong as your DID dsiplay isn't all red when you come across this problem
Old Mar 15, 2012 | 12:46 PM
pa4ul's Avatar
well i had checked my circuit board. It looks fine. Just sometimes it wouldnt engage the shifter. I had to kinda slap it around a bit to get her to engage. LOL sounds so dirty! But she still shifts when need be. only on highways though. Need to conserve gas!
nwssinc
Dec 18, 2017 06:27 AM
MACattack
Feb 3, 2013 02:55 PM
jackson101
Jun 18, 2010 10:06 AM
Ramathorn
Sep 29, 2008 12:18 AM
Quattro11
Aug 26, 2004 02:53 PM
