Shocks
Old Jul 8, 2008 | 03:35 PM
zchb9's Avatar
Default Shocks
Hey,
So the hits just keep coming. I have now replaced inner tie rods, O2 sensors, Rotors, Brakes, and Brake lines. Money is getting low. My right front shock is now drying out and sounds terrible. I would like to lower the car but at this time not so sure about the money. Anyway do you know of any quick fix or should I just go ahead and replace it? If I replace one should I replace both or all 4? What would you suggest as the best bang for the buck?
Thanks all
Zach
Old Jul 8, 2008 | 09:53 PM
ghost6303's Avatar
Default RE: Shocks
i picked up some tien springs from a junkyard car for $70 and some billstein sport shocks for $480 off ebay. lowers 1-1.5 inches. the car handles like a dream now. you could spend the $1300 + instalation for some coilovers for a somewhat better ride, but if money is a concern, that is the way to go.
you can get away with doing only the front or only the rear, but you cannot do only one unless your just replacing the stock one with a stock one.
Old Jul 8, 2008 | 10:07 PM
1781cc's Avatar
Default RE: Shocks
ORIGINAL: ghost6303
ehh, I guess as a temporary solution it would be okay, but you shouldn't consider replacing 1 shock a permenate fix. Espically with used shocks, it will create uneven balance and cause pre-mature tire wear. Do shocks in pairs at the minimum, and idealy all 4 at the same time. Because, even when you do them in pairs, it's going to cause front or rear bias slightly on the worn pair of shocks.
brownboy1690
Jun 2, 2010 07:14 PM
dale55
Sep 7, 2009 09:06 AM
v1nyd
Nov 12, 2008 08:07 PM
gibson 01
Apr 16, 2008 05:48 PM
mingblueA4
Jul 23, 2005 06:02 PM
