Sluggish performance
Hi,
I recently changed the time belt on my wifes a4 1.8t with no issues in about 4 hours. Thing is when driving it doesnt want to rev in 3rd gear (well not like it should) I checked and re-checked the timing and used vagcom. Its showing and intermitent fault on cam shaft sensor. I put boost gauge on and it wont go over 8psi I also performed a boost leak test which found a leak on the tee under the inlet manifold running from the manifold then to the block, could this be the problem? as I would think its similar to running a catch can system but could be wrong. I have been told to do a compression test which i will do but Im sure its ok as nothing moved from its marks during the tb change.
Scott
Scott
Ok so i checked it all again and also compression which is 150 in each cylinder (with leaking comp tester as it didnt fit all the way down so i had to mod it) and timing marks are perfect but the cam senor code came back as intermitent fault, so would that be the issue?
im really confused by this, I have read in places that many people that change the sensor (camshaft) usually have the same problem re-appear, some say it ended up being a faulty cam chain tensioner causing some slack between the cams and triggering the code? I will do throttle body adaptation and get some actual readings tomorrow but its getting annoying. lucky i like audi's lol
