Sluggish performance
Old Feb 13, 2012 | 04:52 AM
ziller's Avatar
Default Sluggish performance
Hi,
I recently changed the time belt on my wifes a4 1.8t with no issues in about 4 hours. Thing is when driving it doesnt want to rev in 3rd gear (well not like it should) I checked and re-checked the timing and used vagcom. Its showing and intermitent fault on cam shaft sensor. I put boost gauge on and it wont go over 8psi I also performed a boost leak test which found a leak on the tee under the inlet manifold running from the manifold then to the block, could this be the problem? as I would think its similar to running a catch can system but could be wrong. I have been told to do a compression test which i will do but Im sure its ok as nothing moved from its marks during the tb change.
Scott
Old Feb 13, 2012 | 08:26 AM
M5S5's Avatar
Tech Certified
I would check the cam timing again. It is probably out causing the ecm to go into fail safe mode preventing maximum power.
You should not have any cam sensor codes after timing belt work!
Old Feb 13, 2012 | 12:07 PM
chocalotstarfish's Avatar
Super Moderator
Check everything a 3rd time. Also unless your modded 8lbs is about right
Old Feb 13, 2012 | 03:44 PM
ziller's Avatar
Ok so i checked it all again and also compression which is 150 in each cylinder (with leaking comp tester as it didnt fit all the way down so i had to mod it) and timing marks are perfect but the cam senor code came back as intermitent fault, so would that be the issue?
Old Feb 13, 2012 | 04:16 PM
MetalMan's Avatar
Have you cleared the fault code(s) and checked to see if it (they) come(s) back?
Old Feb 13, 2012 | 04:30 PM
ziller's Avatar
it didnt come back right away but yes after the second check with vdcs lite it came back
Old Feb 15, 2012 | 12:57 AM
bmoore98A4's Avatar
dude 8psi is spot on from factory. 150 all the way across is good. If your cam is off to the point its not running right wouldnt that destroy your compression test??
Old Feb 15, 2012 | 04:35 AM
ziller's Avatar
im really confused by this, I have read in places that many people that change the sensor (camshaft) usually have the same problem re-appear, some say it ended up being a faulty cam chain tensioner causing some slack between the cams and triggering the code? I will do throttle body adaptation and get some actual readings tomorrow but its getting annoying. lucky i like audi's lol
tjtim
Jan 26, 2015 02:18 AM
Dasoslukos
Jun 3, 2009 01:27 PM
theTTkid
Aug 22, 2007 08:59 PM
MTLA4
Jul 18, 2006 07:24 PM
JugheadA6
Jul 4, 2005 01:42 PM
