smallest rim size i can run on a b5?
Old Dec 21, 2012 | 08:55 AM
  #21
redline380's Avatar
Legal Moderator
I should mention the size of the wheel doesn't matter much its the size of the tire. For instance my 15's run 195/65 tires, my 17's run 225/45 tires. Not much difference in rolling diameter. I will admit the smaller wheels give a better ride because of the extra sidewall on the tires. But the ride height is essentially the same.
Old Dec 21, 2012 | 10:50 AM
  #22
meloman's Avatar
Originally Posted by meh.
I'm not sure if you're referring to me, but I was calm all along.
I made a joke about deleting the rear brakes (originally from AZ) and OP got mad.
I never called OP names or anything.
I just sat back and enjoyed his anger.
No no no, I was cometely agreeing with you meh.
The op is just always trying to pick fights in threads for no reason.
Old Dec 21, 2012 | 10:54 AM
  #23
meloman's Avatar
Also for what it's worth, lowering springs would essentially make the car "quicker" with a stiffened up suspension you won't have as much body movement or "dump" in the rear when you launch and lower will have better aerodynamics than a stock height car, just food for thought.
Old Dec 21, 2012 | 12:42 PM
  #24
kriptonik's Avatar
^ what he said. If you wanna do launches and be quick as heck, lower the car.
And LOL @ meh.
Old Dec 21, 2012 | 01:48 PM
  #25
meh.'s Avatar
I'm the victim here.
Old Dec 21, 2012 | 08:13 PM
  #26
kriptonik's Avatar
It's not that bad. He just blocked you.
Old Dec 24, 2012 | 07:50 AM
  #27
Subarashī Kao's Avatar
well hello to all i just did the swap and so far i love it me and my friend weight the 15" and the 16" tire and rim with its correct tire pressure and we got a total of a clean 7lb difference between 15" and 16" i saved 28lb total took my baby out raced a 350Z from a dig he beat me by close to a car rematch soon since i had stock cat stock dp so lets see how that goes. over all saving the weight where it counts really helps no doubt.
Old Dec 24, 2012 | 10:56 AM
  #28
jonbonesjones's Avatar
Moderator
You know you can save just as much by runnong a bigger, lighter wheel. Lets see pics with the 15s
Old Dec 24, 2012 | 02:27 PM
  #29
chocalotstarfish's Avatar
Super Moderator
So a car with twice the hp and same weight but it was close?
Old Dec 24, 2012 | 03:44 PM
  #30
livinglegend2100's Avatar
just some more food for thought here, but having the lightest wheel/tire combo possible isnt exactly ideal. Since you are using your weight savings as a performance bias, I would look into how inertia effects a cars performance. reducing your rolling resistance is nice, but you can go too light and it will actually hinder your performance. expecially with big fat 15" tires. theres a reason you dont see people on the track with small wheels and giant side walls.
again. just my .02. throw some pictures up of the car with the new wheels
