smallest rim size i can run on a b5?
Old Jan 11, 2013 | 08:13 AM
  #51
CCA4's Avatar
Originally Posted by awdjunkies
Interesting thread to say the least.
Why couldn't you just let it die!?
Old Jan 11, 2013 | 10:47 AM
  #52
B5 Audi's Avatar
why couldnt you just let it die???
oh wait
Old Jan 11, 2013 | 01:03 PM
  #53
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Whats going on in here?!
Old Jan 11, 2013 | 04:10 PM
  #54
meh.'s Avatar
I miss OP.
Old Jan 11, 2013 | 05:52 PM
  #55
chocalotstarfish's Avatar
Super Moderator
Old Jan 12, 2013 | 08:26 AM
  #56
tofast2belast's Avatar
Originally Posted by livinglegend2100
just some more food for thought here, but having the lightest wheel/tire combo possible isnt exactly ideal. Since you are using your weight savings as a performance bias, I would look into how inertia effects a cars performance. reducing your rolling resistance is nice, but you can go too light and it will actually hinder your performance. expecially with big fat 15" tires. theres a reason you dont see people on the track with small wheels and giant side walls.
again. just my .02. throw some pictures up of the car with the new wheels
you sir are correct. smaller rim does save weight, but also changes the moment of inertia. too small will be harder for it to change its rotational rate. a larger diameter will be easier to put torque down off the line, will cover longer distance in one revolution, but takes longer to make one revolution. hence why are breaker bars long. if they made a breaker bar the size of an average socket wrench, it wouldn't be a very good breaker bar now would it?
and large sidewalls on a race wont be ideal either like you said, there is too much flex in the wall, when **** stretches, **** will break.
if you can find a rim thats the same size and lighter, that would be more ideal.
why not tell the op get some 15 inch rim with 205/35 tires. it'll make him think hes accelerating faster. which he would, but its marginally noticeable if that.
also last thing, changing rim/tire diameter effectively changes the final drive ratio. and messes with the speed sensor.
Old Jan 12, 2013 | 09:11 AM
  #57
01 Avant's Avatar
all that work for 26# - why not just take the spare tire and tools out of the car
on a side note, I'm happy to know that when you checked the wheel/tire weight, you had the correct air pressure...
Old Jan 12, 2013 | 10:35 AM
  #58
CCA4's Avatar
Originally Posted by meh.
I miss OP.
He misses you too
Obvious troll is obvious
Old May 25, 2013 | 10:39 PM
  #59
daze614's Avatar
Not any constellation....thats my monkey on the right. 15" BBS Audi meshies from an old *** GT if im not mistaken. Car had sport suspension or some **** on it when i got it. Tires are 195/55-15. Not bad oberall look and stance in my opinion. Could be lower. Wheels could be bigger. But the homegrown budget kicks *** when pulled off properly!! Its all a personal taste
Old May 27, 2013 | 12:10 AM
  #60
hartsoe1's Avatar
Cool
wait, but if you only had 28 lbs of air instead of 35 lbs you would save some more weight.............
