sneaking in a resonator
Old Dec 28, 2011 | 09:05 PM
TheMilkMan's Avatar
Default sneaking in a resonator
so right now my 2001 a4 1.8t has a 2.5 inch straight pipe from the cat back. everything else on the car is pretty much stock. when i let it scream, it sounds awesome. however, at low rpms, it sounds like a worn out camry. what kind of resonator can i weld in that will clean up my idle and low rpm sound, but keep the high rpms sounding mean and raspy? im open to all suggestions.
also- i have a 50 dollar gift card to ecs tuning, any ideas on how i should spend it?
Old Dec 28, 2011 | 09:12 PM
MetalMan's Avatar
Have you considered an aftermarket high-flow cat or test pipe in place of your cat? That will allow it to sound deeper/throatier/meaner. Then you can put in a resonator as well. My car runs a Magnaflow resonator, not sure which model but it's round and is 2.5" in/2.5" out.
Old Dec 28, 2011 | 09:15 PM
TheMilkMan's Avatar
was thinking about this
Audi B5 A4 Quattro 1.8T > Exhaust > Test Pipe > ES#1844140 B5 1.8T Race/Cat Delete Pipe Kit - ATP-VVW-138
is this a simple bolt in and out? it looks pretty tight underneath the car. how easily can i avoid a check engine light?
Old Dec 28, 2011 | 09:31 PM
MetalMan's Avatar
That will fit directly. This is what I use to get rid of CEL due to a high-flow cat:
O2 Sensor Spacer, For Bosch Style Sensors - 034 MOTORSPORT
Old Dec 29, 2011 | 08:26 AM
ImTheDevil's Avatar
I run a Vibrant 12" perf-core resonator along with a Magnaflow 14816 and custom cat-back piping and love it. The resonator makes the tone a lot deeper than the OEM resonator. I have a 30v but the 1.8T seems to have similar results with exhaust mods.
Old Dec 29, 2011 | 09:30 AM
CCA4's Avatar
I use the same spacer on my TP and have yet to see a CEL. To be fair though, it's only been installed for a day lol
99b5avant
Apr 26, 2010 03:11 PM
dmfan016
B7 Models
May 31, 2009 07:56 PM
germantech
Mar 5, 2008 04:52 AM
balkranjit
Apr 22, 2007 10:26 PM
