software for vag-com tool
could be a problem with the radio wiring harness, OBDII port, or your cheap cable. a lot of people have reported problems trying to scan their car when they have an aftermarket radio installed. if you can hook up and get at least a partial scan (radio) then the software is working properly.
VCDS-Lite is the replacement for the old VAG-COM versions 311 and 409, and it's compatible with all interfaces which worked with those old VAG-COM versions.
If VCDS-Lite is having problems, the first thing to do is [Options] -> [Test] and post the exact results.
-Uwe-
so this is what i get but still i don`t understand why the only thing is dectecting is the radio module,and what i noticed when it scans is that only at the radio module switches to baud 02 on the rest doesn`t is only 00 or 01 on all attempts why is that ?
Latency Test: Poor
If it uses an FTDI chipset, install the latest drivers from ftdichip.com, and then crank down the latency timer to 2, as shown in this screenshot.
If your interface uses some other chipset, talk to your interface supplier.
-Uwe-
