SPC 81350 Adj Control Arms
has anyone installed these and can you say what camber you adjusted to to prevent tire wear ?
SPC 81350 Audi B5, B6, B7, C5, and VW B5 Adjustable Front Control Arms!
SPC has released this Set of 4 adjustable front upper control arms which will allow +/- 1.5 degrees Camber and/or Caster change for these vehicles. These arms directly replace factory fixed-length arms, allowing easy adjustments after installation. Engineered for both street and track use, forged 6061-T6 aluminum ends with large 18mm threaded adjuster links assure this is the strongest kit available. Maintenance free ball joints and bushings provide factory ride, handling, and NVH performance.
Click here to see the installation video :
These come as a SET OF 4 and fit the following models :
Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
Audi A6/RS6 (incl. AllRoad) - 1998-2004
VW Passat - 1998-2005
This product is SPC 81350 and replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
I don't know, but I was wondering this exact same thing yesterday, as my car was on the alignment rack, showing how bad the camber was out - which can't be adjusted unless you move the entire sub-frame.
I can't speak for this brand personally, but I'm sure adjustable control arm are definitely worth getting.
Notice how I banned him. I gave him the benefit of the doubt with only a 7 day ban so he can contact me, but that will turn into a permanent ban I am sure. I anyone sees ads like this please let me know
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
