Speedomete and Tachometer not working
Old Jul 30, 2023 | 06:15 PM
ProfileTrader's Avatar
Today I tested the plug wires - all are good. Also the plugs are not that old and they are NGK not some cheaper brand.
I did notice something today. when I turn the ignition (key) to the on position just before starting the car I can watch the speedometer and depending on what I see I now know if I continue if it will work or not. So If I turn it and I see it will I continue quickly and it works if I do not I turn it off and then on again until I do. What I see is the needle move off of zero slightly. If it does it works and if it does not it won't (if I drive). So what does that mean? What signal is being transmitted to the speedometer and from where? Also if the speedometer does this and I start the car the the tach works {as does the speedometer) and if it does not neither does.
Old Aug 11, 2023 | 01:17 PM
Did anyone ever find a resolution to this problem???
audinoob27
Mar 5, 2012 06:24 PM
Bigrigatoni
Oct 3, 2008 04:28 PM
lakers3021
Aug 25, 2007 11:10 PM
lakers3021
Jul 31, 2007 12:51 AM
