squeeking coming from back passenger tire
Old Jan 26, 2009 | 06:43 PM
rplets15's Avatar
Default squeeking coming from back passenger tire
so when i first heard the squeeking i asked on here and you guys said it was the wheel bearing but it only squeeks when im brakeing under 25mph so i thought maybe the brakes were goners. so i checked them but no they look practicly new so anyone have anyideas on what it is? is it the wheel bearing?
Old Jan 26, 2009 | 07:45 PM
ImTheDevil's Avatar
Check the condition of the ball joints - you could have a control arm replacement in your future.
Old Jan 26, 2009 | 07:50 PM
ryanylva's Avatar
Sway bar bushing or spring cracked at bottom weld are 2 common ones.
Old Jan 26, 2009 | 08:51 PM
SAudi's Avatar
wait a second is it a sqealing like a brake sqeal or a squeaking because they're 2 diferent thing, int he other post i said it was may the rear sway bar or similar rubber part but if its a brake sqeal you may just need some anti sqeal or grease on the back of the pads.
Old Jan 27, 2009 | 01:26 PM
brrman's Avatar
A wheel bearing does not squeak. It grinds and rumbles at speed.
Push down solidly on the corner of the car that has the squeak. If it squeaks when you do this you have a bad control arm "bushing". Bad bushings squeak like two balloons rubbing together. Bad ball joints give a knocking sound when you drive over a bump, etc - the cup has stretched and the ball is slopping around in there.
Like SAudi said: If it's a squeal (as opposed to a squeak - you should know the difference) when you brake then it's your brake pads.
Old Jan 28, 2009 | 12:01 AM
rplets15's Avatar
ok thanks for the help guys i did try pushing on the corner of the car i heard a little sound but it wasnt really a squeek so i just tried the cheep thing and got some brake quiet and sprayed it on there and so far it hasnt squeeked anymore but im gonna keep my ears out
Old Feb 4, 2009 | 06:34 PM
rplets15's Avatar
well the brake quiet stuff worked for about a week now it squeeks while im driving i still dont hear anything when i push down on the corners but i still do it every other day and listen i think i might of heard like a littl vibrating sound one time but thats it any ideas? also its not a constant squeek its like a pulsating squeek
Old Feb 4, 2009 | 07:40 PM
A4Cragman's Avatar
I heard the same thing coming from the back drivers side of mine once and thought it was the same thing, but one day, it started doing it when the car was just idling and i wasnt moving anywhere so i got out and looked and the little rubber clip things that hold the muffler onto the chassis were squeaking as the muffler vibrated from the idling engine. How to remedy this, i do not know, but i havent heard mine doing it in awhile so i havent thought much about it, but you could check that and see if that's what you're hearing.
Old Feb 5, 2009 | 12:20 AM
brrman's Avatar
yeah I was also about to suggest something rubbing due to vibration. The exhaust hanger might just be it.
Old Feb 5, 2009 | 01:09 AM
A4Cragman's Avatar
Yea, I know thats what it was on mine cuz when I tapped the muffler as I heard the sound, it stopped instantly. Sure wish I knew of a way to make it stop for good. Maybe some WD-40 or silicon lube or something of that sort on the rubber parts that hold it on?
esandes
Mar 14, 2012 07:01 PM
Tourbo24
Apr 8, 2011 08:51 AM
rtoys4
Jun 27, 2010 10:18 AM
rplets15
Jan 26, 2009 08:46 PM
