stabilizer mount
Old Feb 21, 2009 | 10:48 AM
mrbloink's Avatar
Default stabilizer mount
is there a tutorial on how to replace or fix my stabilizer mount. I was told that mine is about falling off and I was wondering if this is a simple fix. I was quoted $175 for the job. but f i could do it, it would be nice to save the cash
Old Feb 21, 2009 | 11:18 AM
Tweaked's Avatar
Are you referring to the stabilizer bar mount (sway bar mount)? Front or rear? Do you have after market sway bars?
Old Feb 21, 2009 | 12:18 PM
mrbloink's Avatar
front and stock
Old Feb 22, 2009 | 12:14 AM
Tweaked's Avatar
Originally Posted by mrbloink
front and stock
There are two bolts holding each mount in with a bushing.
Old Feb 22, 2009 | 09:18 AM
mrbloink's Avatar
so I am guessing that if they are estimating $175, then they are probably replacing the mount? how will i know if the mount needs replacing or if it just needs bolting back together?
Old Feb 22, 2009 | 12:42 PM
hiwords's Avatar
well the mount is just a like a half circle thing with 2 things sticking out on each side for bolts. take a look and you'll see.
Old Feb 24, 2009 | 04:05 PM
Tweaked's Avatar
Your bushings are probably shot. It's a quick job and worn bushings are relatively inexpensive to replace. If the mount is broken because you nailed a rock or something, then likely yes, they are replacing the mount and the bushing.
Old Feb 24, 2009 | 10:29 PM
mrbloink's Avatar
i havent hit anything with the car. so hopefully the mount isnt shot. will this happen from regular driving
Old Feb 24, 2009 | 10:48 PM
Tweaked's Avatar
The bushings wear out from regular driving, but we still aren't sure exactly what's wrong with your car. Can you post a pic?
Old Feb 25, 2009 | 08:44 AM
mrbloink's Avatar
I will try to jack it up after school in the short time that I have befor work. I will snap a pic of both mounts as I am not completely sure which side it is on. Will I be able to tell if it is just the bushings that have gone bad without removing the mounts? Also, I hear a ratteling coming from I think the front right of the car. I am guessing that this is the mount ratteling around. Admitently, I probably do sometimes take corners a bit faster than I should with the stock sway bars.Hopefully my old crappy jack wont fail on me this time.
