Stalled and not starting
Purchased an 01 1.8T a month ago that has stalled and I can't get it started. It sometimes has a pulsating idle and gets low enough to stall. Has happened twice in the past. Third time it won't start anymore.
I've check fuel flow, took the throttle body off and cleaned it and tried with the MAF unplugged. Spark plugs look ok.
I'm about ready to take it to the local Euro shop but thought I'd try here before I do. I've done some searching and there are a ton of threads that seem relevant but were never closed out (had a solution added).
Questions:
Is there a way to test the spark packs?
Anyplace else to look/check?
The EPC light is on while the key is on and the car is turning over, is this normal or is it trying to tell me something? It wasn't on when the car was last running.
Also no code/CEL.
TIA
Bob
Questions:
Also no code/CEL.
TIA
Bob
@kinyslayer: Did you have to drain your tank and refill to get it started, or did some additive get you moving again?
@shoot2thrill: Did you try cleaning first? If so, where did you find the tool to take the sensor out of the horn?
Thanks,
Bob
Thanks,
Bob
OP, did you actually scan it or are you telling us it has no codes because it has no CEL? You can have codes w/o CEL. Otherwise, all I can say is check your fuses... all of them. There are ones that shouldn't matter but do. I pulled the ABS fuse from the inside fuse box on my car and it refused to start at all that way.
