Stock Boost Preasure
Old Apr 16, 2013 | 09:47 PM
phatjames167's Avatar
to and from work today i was boosting around 5. I was reading that the 01+ are fine to run with out the MAF so I JUST uninstalled the MAF, took the car out from not being run in a few hours and at first was boosting around 8-9 then as the engine and oil was warming up i was boosting around 10-11. so my first question is as the engine warms up will I boost more and second does this sound like a MAF issue? If so should I clean it or just replace it?
Old Apr 17, 2013 | 02:10 AM
redline380's Avatar
Legal Moderator
the thing is you cant just run without an maf. im surprised your car boosted that much without on in it. what happens is that when the maf is unplugged, the ecu reverts to pretermined timing/fueling to prevent the engine from burning up. however, since 01's have map sensors and wideband, running without an maf is a little easier. however, it still needs to be present for the car to run properly.
if you are going to do anything with the maf, dont clean it. replace it. cleaning it wont last long. regardless of the pming we have done, buying used maf's, i think, is a great idea. brand new ones cost a ton, and dont buy anything besides a genuine bosch
Old Apr 17, 2013 | 08:50 AM
I totally agree I need the MAF, i only removed it for testing purposes. some of the posts i read were that the 01 should be ok with out it and to run without it to test if the MAF may be bad. based off being able to boost higher with out it should indicate its bad I think. on the ride in this morning with out it i was hitting 9-10, not quite the 14-15 i was seeing when I first installed the boost gauge but definitely better and noticeable.
also PM'd you back.
Old Apr 17, 2013 | 07:27 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
I just looked up the MAF for your AWM 1.8 engine, it's 06A906461LX and runs 134.07 for this remanufactured unit. Plus a core of 25.00 but you get that back once I get your old one. You pay the shipping from me to you of about 10.00, plus whatever it costs you to send me your old one. Once we have the old one we will credit you back the 25.00 providing it's a good core. We have one in stock too. Thanks, Jeff.
Old Apr 17, 2013 | 09:17 PM
I got one on the way from redline380 but if for some reason i need a new one i'll keep this in mind.
Old Apr 18, 2013 | 12:32 AM
redline380's Avatar
Legal Moderator
should be there friday or saturday. im pretty sure a different maf will help your problem
Old Apr 22, 2013 | 09:32 PM
After the MAF install I'm down to one code being thrown, P0455: Large evap leak. any ideas?
Old Apr 22, 2013 | 10:54 PM
  #18
redline380's Avatar
Legal Moderator
Glad the mad helped. If you got an evap leak, you'll have to inspect everything. Or it could be the purge valve too
MK1audiTT
Apr 21, 2008 05:26 PM
andrei
Jul 22, 2007 05:38 PM
eastkendallkid
Mar 7, 2007 03:48 AM
eastkendallkid
Feb 5, 2007 11:21 PM
victor
Oct 26, 2006 10:50 PM
