Stock fog light wiring/conversion...
Old Mar 29, 2008 | 05:08 PM
410ThirtyValve's Avatar
Default Stock fog light wiring/conversion...
Does anybody know whether or not the wiring/connectors for the fog lights imbedded in the stock headlights can be used with the bumper style stock fog lights. I have a 1998.5 2.8Q 30 V that has fog lights in the headlight with a fog light button in the interior. I am trying to switch to the more common bumper style fog lights using the same connection from the headlight. (Also looking to fit them into a b5 s4 bumper...but thats not my main concern for now.) Has anyone done this?? Is it possible? Is it difficult? Any help would be great.
P.S. I already searched through the millions of pages on fog lights.
Old Mar 29, 2008 | 06:27 PM
ImTheDevil's Avatar
Default RE: Stock fog light wiring/conversion...
Look at the plug-in harnesses that connect to the headlight housings. The green/white wire is the one for the fogs. Use a wire-tap to connect to it, and run a wire down to the foglight. Ground the other fog connector somewhere inside the bumper and you're done.
Old Mar 29, 2008 | 10:02 PM
Hey thanks...info much appreciated.
Old Mar 30, 2008 | 09:20 AM
ImTheDevil's Avatar
No problem - just make sure that when you wire up the lower fogs, you use extra wire so you can change the bulbs easier. I used about 4' of wire from each harness to its respective foglight, since I didn't have harness connector plugs to use on the fog housings, and instead had to wire directly to the plug tines with blade-style wire connectors. With the four-foot long wires, I can remove the fog housings easily and then disconnect/reconnect the wires, instead of having to reach inside the grilled and do it blindly by touch.
DewAudiA4
Feb 17, 2013 09:23 PM
lucyislay
Oct 21, 2010 05:59 PM
secmil
Apr 1, 2007 10:01 PM
VB05
Jan 28, 2006 07:49 PM
krue92
Aug 1, 2005 02:53 PM
