Sunroof ?
Old Mar 9, 2010 | 05:10 PM
lolo22's Avatar
Default Sunroof ?
Let me just start off by saying im new to the audi scene just picked up my first a month ago and by far the best car Ive ever owned. Just wondering on the sunroof besides a fuse is there any other reason why It may not work is there a relay or something else. Its a 1998
Old Mar 9, 2010 | 05:45 PM
aRIf's Avatar
motor could be dead.
also sunroof switch can fail. push the switch up gently and turn it to see if any thing. sunroof switch is a common problem on audis. switch sometimes lose connection u have to take the cover off and unscrew 2 screws to fix it. easy job, takes < 5mins.
Old Mar 9, 2010 | 05:46 PM
Andrew149's Avatar
never heard of one not working when you open the driver side door there a panel pull that off
Old Mar 9, 2010 | 08:34 PM
CCA4's Avatar
bad sunroof motors/switches are fairly common on B5's. for the record, OP, there's a little crank on the inside of the fuse panel door that you can use to close the glass if it gets stuck open
Old Mar 9, 2010 | 09:40 PM
pullacowonaski's Avatar
there is also a diy on how to clean the contacts i need to do that to mine it acts all funny
Old Mar 11, 2010 | 06:31 PM
lolo22's Avatar
Turns out the switch wasnt pluged in I guess for a reason. I pluged it back in and cleaned the contacts and when I turned it on it made a loud clicking noise it opend but then wouldnt shut and I had a hard time doing it manually cause it would just keep clicking like its stripped. The noise is coming from the location of the screw to close it manually. Any Ideas.
Old Mar 21, 2010 | 02:50 PM
rawdney88's Avatar
im in the same boat with my audi a4 1998 2.8L v6 , opens fine, won't close. manually it sounds like a gear is loose or stripped. quite annoying.
mrocke440
Nov 20, 2010 09:11 PM
tariqahmad
Oct 16, 2009 11:49 AM
18T
May 15, 2006 08:27 PM
a6speed
Dec 10, 2005 07:18 AM
TheHolyGhost
Aug 10, 2005 01:31 PM
