suspension
Old Jan 16, 2013 | 10:04 AM
phatjames167's Avatar
Default suspension
when i move the steering wheel left or right i don't have to move it much, it turns quickly but the suspension to me feels a little loose. what all can i do to stiffen it up some?
Old Jan 16, 2013 | 04:31 PM
ImTheDevil's Avatar
Sounds like weak tie rod ends to start with. Replace them with S4 TREs - it'll tighten things up.
Old Jan 16, 2013 | 05:12 PM
bshusted's Avatar
Another thing to look at are the sway bar end links. The stock ones are aluminum with soft rubber bushings. You can improve turn in response by going with end links made with spherical bearings (no slop). Many people have used the REAR sway bar end links from the Subaru WRX with good success. There is a writeup on Audizine about it.
Old Jan 16, 2013 | 06:10 PM
hartsoe1's Avatar
jack it up, grab the tire at left and right (3 and 9 o'clock) and get a feel for the play in your old control arms. I was surprised at the play in mine and I just did a full front control arm replacement, the S4 upgrade from fcp.
Old Jan 17, 2013 | 07:27 AM
jonbonesjones's Avatar
Moderator
Running WhiteLine 04 STI rear sway bar link on my front I traced down a rear option a while ago i think some older toyota shares the same length and overall it looked like it would fit, but I think ill just make 2 custom adjustable end links in the summer.
Old Jan 17, 2013 | 12:49 PM
Is FCP FCPeuro.com? I'll most likely so the s4 upgrade, i was also planning on doing my control arms in a couple months when i do my front axle's.
Old Jan 18, 2013 | 07:03 AM
Moderator
FCP Groton
I got the S4 upgrade kit, im not sure what the difference is?
I got it actually because on the S4 with alumn front uprights have a different straight control arm, not the case at all.
Old Jan 18, 2013 | 07:12 AM
ImTheDevil's Avatar
JBJ, what do you think of the STi end links compared to the A4 links?
Old Jan 18, 2013 | 10:05 AM
Moderator
Heavier duty and pretty gold stiffer I feel it
Cheaper and more proven than anything I've seen offered for the the b5
Old Jan 18, 2013 | 04:44 PM
hartsoe1's Avatar
S4 upgrade vs normal control arms. I don't think they even sell the 'standard' arms at FCP, and I couldn't really tell the difference as i was installing them. by the way, save your old nuts and bolts until you have completed the job and have driven it around (don't ask how I know). Also, the 2 bolts through the strut at the lower arm in my kit had a fine thread but no fine thread nuts were included, so I used the old ones.
