swapping A4 sunroof assembly from 2000 Jetta?
Old Jun 30, 2012 | 02:42 PM
billymoon's Avatar
Default swapping A4 sunroof assembly from 2000 Jetta?
i bought a 1999 A4 and unfortunately the sunroof has an number of broken parts totaling $500 (for the parts alone). my old car is a 2000 Jetta VR6, which i haven't sold yet. it has a few other issues so the sell price won't be much, and i'm wondering if i should add "broken sunroof" to those issues. any problem simply swapping the whole assemblies between the two makes/models, other than the general hassle of pulling headliners and removing/reinstalling assemblies?? thanks for any advice.
Old Jun 30, 2012 | 03:11 PM
vgo's Avatar
vgo
The Passat is the VW model that have most common interchangeable parts for our A4's.
Old Jun 30, 2012 | 04:57 PM
redmond1501's Avatar
I got a complete sunroof assembly, with motor for $60 at a local salvage yard.
Tips
+ Do not test the sunroof mechanism with the glass removed -- it will destroy the mechanism.
+ Use a trim remover tool to remove the pillar trim and headliner so you don't break the pillar plastic and/or crease the headliner.
+ When you get inevitably frustrated after dealing with the sunroof for a couple hours, don't get grease on the headliner by accident.
+ RECONNECT the (4x) sunroof drain tubes.
The motor was shot on my salvage yard assembly, but I used my existing motor.
Old Jun 30, 2012 | 05:45 PM
billymoon's Avatar
i've had no preliminary luck locating a used sunroof assembly, but will keep at it. thanks for the tips, i'm not looking forward to pulling headliner.
i know the passat is closed relative to te A4, but i believe the sunroof is the same in the jetta (?)
Old Jul 1, 2012 | 12:22 PM
Mad Cow's Avatar
According to ETKA a MK4 sunroof actually will fit, strangely enough it's the only other model to share this sunroof. That's for the '99.5 sunroof though, the prefacelift '99s got a different sunroof that isn't shared with any other car sold here.
Old Jul 2, 2012 | 02:10 PM
billymoon's Avatar
thanks for that info, mad cow. by '99.5, you are referring to the audi, correct? (my jetta is a 2000 anyway.) i don't know what half-year my A4 is, can i tell from the vin? i guess i'm wondering if i look for another used sunroof assembly at salvage, what audi or vw models and years would work, or where i might be able to look that up... if it's not too much trouble to ask?
thanks again for everyone's replies.
Alexei1987
Mar 31, 2015 06:09 PM
whiteaudiguy
Feb 26, 2010 06:41 PM
hudsonbr
Aug 15, 2009 04:44 PM
audiguy00
Oct 2, 2006 02:24 AM
audiguy00
Sep 29, 2006 05:54 AM
