sway bar help please..
so im desperately trying to upgrade my rear sway bar and i have seen one for 40.00 w/o the uplinks and bushings and one on ebay with the uplinks and bushings probably going for more. SO the question is do i need or want these or should i get just the sway bar with the mounting brakets w/o the uplinks and bushings?
do you have a link to what your talking about? i havnt come across a decent rear sway bar for under $150 and thats just a crappy addco bar. $40? sounds about how much a junkyard would charge for a used stock rear sway bar.
Don't bother upgrading the rear unless you're going to do it right. In order to get the most from a larger rear bar, you'll have to stick with something like the Hotkis H-Sport with the mounting braces. The stock mounts are way too small and weak to handle a larger bar.
Additionally, if you don't upgrade the rear endlinks with a larger bar, you'll snap those cheesy plastic endlinks in no time and stab a CV boot. PureMS sells the upgraded links. Do it right or don't do it at all.
worthy?
I have a non-sport
Would this be worth even getting in the slightest? or go bigger?
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
i like the new system so far!
B5luver
12-18-2007 12:42 AM
