Temperature gauge
Old Jan 3, 2012 | 04:23 PM
pbrules10's Avatar
Default Temperature gauge
I replaced my coolant temp sensor yesterday in hopes that this would solve my temperature gauge not moving. Well it hasnt seemed to help that much. It will sometimes go to 1/4th of the gauge then drop back down to cold. Whats weird is after the car has been driven and is warm, i turn it off to maybe run into a store or something and when i go to start the car the gauge is in the middle where it should be but after 20-30 seconds it will drop back down to cold. Also sometimes the car will not cold idle (1500 rpm warm up) even when its been sitting overnight in cold temperatures. I have to throw in, this whole gauge situation started occouring after a major coolant leak that took place weeks ago. What could be the problem since I replaced the Temp sensor. Stuck thermostat?
Old Jan 3, 2012 | 04:43 PM
MetalMan's Avatar
Thermostat would be the next reasonable try. It's a cheap job if you're able to capture all the coolant and reuse it. Not sure that a bad thermostat would cause cold start problems but it's worth a try anyways.
fireman9585
Jul 19, 2011 11:51 PM
vasja222
Jul 2, 2009 12:41 AM
mad_hatter
Sep 18, 2008 02:29 PM
AKAUDITT
Feb 24, 2007 09:05 PM
cboyette2232
Aug 28, 2006 03:43 AM
