Test Pipe?
Old Jan 24, 2011 | 10:43 PM
FASTER's Avatar
Tech Slut
Lol, Jeff is confused on which hole to put it in (maybe the reason he is moving an underage boy into his basement)
Sorry Kolbs
Old Jan 24, 2011 | 10:45 PM
turbo kraut's Avatar
Tech Guru
hey if the wife lets me put it in the first or second hole that is fine
beau... do you have facebook... pm me the details
Old Jan 25, 2011 | 08:43 AM
bradtyler02's Avatar
I was gonna say, it doesn't matter which hole you put it in, if she'll let you (or you "accidently" slip)...
Old Jan 25, 2011 | 11:09 AM
Mike-2ptzero's Avatar
Just look on my friend list and you will find him. lol
Old Jan 25, 2011 | 11:24 AM
Tech Guru
done and done... thanks mike
Old Jan 25, 2011 | 04:47 PM
lolo22's Avatar
Originally Posted by bradtyler02
^ true. Search for the Anti- fouler trick that takes two. Drill a larger hole in one, screw it into the second one, install into the TP on the downstream hole (further from the turbo, closer to the DP). Install the O2 sensor... Voila, no CEL. (At least, that's what worked for me... no CEL since I installed my TP about 6 months ago.
Do you remember were you found the write up on using two anti foulers, Ive searched and searched and got nothing. Or do you remember what size drill bit you used to drill it out.
Old Jan 26, 2011 | 09:21 AM
Alright, I couldn't find it again for the life of me, so I went google happy... Here's what I found. Obviously, it's a different car, but the concept is the same. Drill the first one, big enough so you O2 sensor will fit, screw it into the second one, install on down stream O2 hole, install O2 sensor, enjoy...
http://forums.evolutionm.net/evo-how...cel-light.html
Old Jan 26, 2011 | 10:01 AM
  #18
Andrew149's Avatar
wont a test pipe make the engine light come on?
Old Jan 26, 2011 | 10:22 AM
  #19
That's what we're discussing here. If you use the anti-fouler trick, no CEL... it works.
Old Jan 26, 2011 | 04:06 PM
  #20
lolo22's Avatar
Thanks for the Info. The pipe actually came in today but with no hardware, I called them up and they said send it back and they will order me a new one and hopefully the hardware is in the box this time. Luckly its snowing so I cant install it yet.
